psychopomp123
May 28, 2021Luminary
RAX200 1.0.4.120 firmware
Just noticed that firmware 1.0.4.120 is available within the router settings but if i try to click on 'update' then i continously see 'GUI Language Update - downloading and updating the language ...
Njj0425
May 29, 2021Tutor
My Rax200 DL the new firmware tonight all by it self weird can't find anything about it online
jcgallagher
May 29, 2021Aspirant
Same here. Automatically upgraded to 1.0.4.120. Can't find the release notes.
- kc6108May 30, 2021Luminary
Here's the master link that the RAX200 and Nighthawk app use to determine the latest firmware and language files and their download locations:
https://http.fw.updates1.netgear.com/rax200/ww/fileinfo.txt
Here's the master link that the RAX200 and Nighthawk app use to display the release notes of the firmware files:
https://http.fw.updates1.netgear.com/rax200/ww/stringtable.dat
Thus, the direct download link to firmware V1.0.4.120 is...
https://http.fw.updates1.netgear.com/rax200/ww/RAX200-V1.0.4.120_1.0.61.chk
... and the release notes are:
[New Features] Allows LAN devices to use HTTPS to access the router web interface.
[Bug Fixes] Removes EOL feature ReadySHARE Vault.
[Bug Fixes] Removes EOL feature OpenDNS.
[Bug Fixes] Removes EOL feature remote management.
[Bug Fixes] Improves stability.
[Security Fixes] This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
