darknessplayboy
Dec 02, 2019Aspirant
RAX200 1st 5Ghz band issue
I recently purchased RAX200 Tri-band ax12 router, first it got problem with netgear cm1100 modem that would keep rebooting, that never happened with my R9000 ax10 router, so I bought the new cm1200 m...
GabboCH
Dec 04, 2019Apprentice
Do you have AX support enabled & have you tried updating your Intel drivers from the intel website (instead of windows update)?
There is a Knowledge base item from Netgear about this.
I had the same problem with all my laptops & PCs as they use intel Wifi devices which needed the driver update.
- darknessplayboyDec 04, 2019Aspirant
Yes, AX is enabled, and intel ax200 card drivers are latest from the intel website.
- Gport16Feb 14, 2020Aspirant
Did you get anywhere support wise or did it die on the vine? I have similar issue, can only conenct ot one of the 5G channels
