darknessplayboy
Dec 02, 2019Aspirant
RAX200 1st 5Ghz band issue
I recently purchased RAX200 Tri-band ax12 router, first it got problem with netgear cm1100 modem that would keep rebooting, that never happened with my R9000 ax10 router, so I bought the new cm1200 m...
GabboCH
Dec 04, 2019Apprentice
Do you have AX support enabled & have you tried updating your Intel drivers from the intel website (instead of windows update)?
There is a Knowledge base item from Netgear about this.
I had the same problem with all my laptops & PCs as they use intel Wifi devices which needed the driver update.
darknessplayboy
Dec 04, 2019Aspirant
Yes, AX is enabled, and intel ax200 card drivers are latest from the intel website.
- Gport16Feb 14, 2020Aspirant
Did you get anywhere support wise or did it die on the vine? I have similar issue, can only conenct ot one of the 5G channels
