jamie57
Aug 02, 2022Tutor
RAX200 2.4ghz band dropping
I've had this RAX200 for about 3 months now and have been fighting this problem where the 2.4ghz band drops all devices and nothing will reconnect to the 2.4ghz band until I power cycle the router. ...
Aug 02, 2022Guru - Experienced User
Did you disable AX on the router for the 2.4ghz?
you can also try setting the speed down on it. Better to have a little slower 2.4ghz that works than a faster one thats sketchy.
- jamie57Aug 02, 2022Tutor
I haven't tried disabling ax yet. I dropped the speed setting this morning before I left for work to see if that helped, but everything has already dropped connection since I left. I will try disabling ax when I get home this evening.
- plemansAug 02, 2022Guru - Experienced User
When you've reset, have you left everything at its defaults (even ssid/password) and tried it?
- jamie57Aug 03, 2022Tutor
I disabled AX this morning, it is working good so far. I don't see how to disable AX on just the 2.4ghz band though, I only see an option that disables it all together.
