jamie57
Aug 02, 2022Tutor
RAX200 2.4ghz band dropping
I've had this RAX200 for about 3 months now and have been fighting this problem where the 2.4ghz band drops all devices and nothing will reconnect to the 2.4ghz band until I power cycle the router. ...
jamie57
Aug 02, 2022Tutor
I haven't tried disabling ax yet. I dropped the speed setting this morning before I left for work to see if that helped, but everything has already dropped connection since I left. I will try disabling ax when I get home this evening.
Aug 02, 2022Guru - Experienced User
When you've reset, have you left everything at its defaults (even ssid/password) and tried it?
- jamie57Aug 03, 2022Tutor
I disabled AX this morning, it is working good so far. I don't see how to disable AX on just the 2.4ghz band though, I only see an option that disables it all together.
- plemansAug 03, 2022Guru - Experienced User
Try it with AX disabled as is. If it stays stable, I'll find my RAX200 and connect it backup and see if I can figure out a way to disable ax on just the 2.4ghz
- jamie57Aug 05, 2022Tutor
Well it worked fine for about a day and a half. Now its back to dropping the 2.4ghz band daily.
