wingdam
Feb 16, 2020Star
RAX200 2.4ghz fails to connect
I just got a RAX 200 as a gift last week and suddenly the 2.4 ghz won't connect to any device, I get the following msg (WLAN access rejected: incorrect security) 5ghz is fine. I'm running the latest...
DainWei
Apr 04, 2020Aspirant
Yes, this keeps happening to me. Although, it is most commonly the 2.4 GHz, it is not always isolated to 2.4 it can affect both 5ghz and even the ethernet ports.
I have always had to reinstall the latest firmware. It is hit or miss if it will work. Sometimes have to reinstall it 1-5 times before it will work again.
I even returned the router and got another but the issues remains
Truly sad that we pay so much for this for this to happen.
Christian_R
Apr 07, 2020NETGEAR Employee Retired
Hello DainWei,
Have you had a chance to get in contact with our support team regarding your issue(s)?
https://www.netgear.com/support/default.aspx
Christian
