wingdam
Feb 16, 2020Star
RAX200 2.4ghz fails to connect
I just got a RAX 200 as a gift last week and suddenly the 2.4 ghz won't connect to any device, I get the following msg (WLAN access rejected: incorrect security) 5ghz is fine. I'm running the latest...
MrTapper
Apr 18, 2020Aspirant
I've been experiencing the same problems connecting to 2.4GHz wifi.
The connection kept dropping which I found very strange and wouldn't connect to my Sky Q box or my Netgear wifi extenders
I reset my RAX200 to factory settings and cancelled the firmware update and the connection has been stable since.
I'll try and install the latest firmware later.
