jimerb
May 29, 2022Aspirant
RAX200 2.4GHZ unresponsive unless i connect to it with my phone.
My RAX200 works great on the 5ghz channel. I have a webcam that must connect on the 2.4ghz channel. When i connect to it, it is sluggish and unresponsive. I forced it to use channel 6. That imp...
May 30, 2022Guru - Experienced User
Try disabling AX mode and disable OFDMA 2.4Ghz
Uncheck 20/40Mhz.
Try channel 1.
- jimerbMay 31, 2022Aspirant
If i disable AX mode it seems like a master switch for both 2.4ghz and 5ghz. Do I want to disable it for 5ghz?
My 5ghz band works good at the moment.
These settings are way over my head.
I live in a NY suburb. Dozens of houses all around me.
