Alpha_K
Mar 25, 2021Tutor
RAX200 2.5Gbps Multi-Gig port throttling?
I am posting here because my warranty support expired, and I have to cough up $90 to ask Netgear for help. Seriously bogus on a product that I spent a fortune on. I purchased the RAX200 router an...
Alpha_K
Mar 26, 2021Tutor
Nope, all of that is turned off. I tried the previous three versions, and it did not solve the problem. Getting close to RMA the device, but I'm not sure how I feel about that.
dayjob
Mar 27, 2021Guide
Yea there was another major thread about 6 months ago related to this router and any link aggregation enabled and using a modem for xfinity. It causes some issues and even if it begins fast, it will throttle way below normal and remain stuck until a full power cycle. No firmware for modem nor router solved the issues. Just cannot use link aggregation for internet period.
Also there is another unsolved thread where using anything other than an unshielded ethernet cable between the router and another device can cause random disconnects or throttling. Cat7/8 or anything saying it's shielded is a problem. There is one trick which helps if you only have shielded cables, and that is to use a female to female cat5/6 connector to break the shielding connection.
Good luck. (If I find previous posts I will update with links)
- koa132435Aug 04, 2022Star
I have a similar problem when using the 2.5 Gbps with or without LAG configured.
RAX200 Owners - 2.5 Gbps throttling? Can you get ... - NETGEAR Communities
Were you able to fix this problem?
