wingdam
Mar 06, 2020Star
RAX200 5ghz password problems
After working flawlessly for the last month, all my 5ghz equipment (phone,echo, cameras,etc.) dropped off with the msg incorrect password. I rebooted the router same thing, I then changed the 5ghz pa...
Jason0
Aug 25, 2020Aspirant
I have the same router and have the exact same problem. Just bought this and set it up. Worked perfect for a couple of weeks. Now all of a sudden today started kicking out all devices and saying that password is invalid. I dissabled smart connect and connected most devices back to 5 ghz band and so far that works but now nothing will connect to 2.4 ghz band. None of my smart home devices. Says invalid. I paid $600 for this thing. This is absoluely unacceptable. It is updated to the latest firmware. 1.0.2.98_1.0.54
