DGSKC
Mar 09, 2022Follower
RAX200 adding SSD USB Drive
I'm trying to add a 2T SSD usb harddrive to the router to use as network storage. So far, WD Black and Samsung T5 don't work. Any suggestions for a 2t ssd usb drive that will work?
Mar 09, 2022Guru - Experienced User
Problem with them is that if they require a driver to be installed, it won't work.
I've got an rax200 but not a 2tb ssd to connect.
A couple things to check.
1. make sure its provisioned prior to installing it.
2. make sure its in the proper format
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
