dmturner
Jan 12, 2020Aspirant
RAX200 always crashes when transmitting 900mbps+ (wirelessly only) for more than 10 seconds
This router performs normally with light traffic until it transmits more data. You can stay connected to the network for a bit but even the router's internal web interface will not load. Then you hav...
- Jan 13, 2020
have you tried to see if the issue happens if you're not running wan port aggregation? I've seen issues with arris running wan port aggregation on my RAX200.
Jan 13, 2020Guru - Experienced User
- dmturnerJan 13, 2020Aspirant
Thanks for the advice, I should have tested that initially.
That actually resolved the crashing immediately during a speedtest.net test.
It would be great to be able to use the bonding feature but I know none of these ax11000 routers are very well supported yet.
Thanks again!
- plemansJan 14, 2020Guru - Experienced User
Sadly its not isolated to RAX. My netgear cm1100 worked fine with port aggregation but my arris wouldn't.
