dmturner's avatar
dmturner
RAX200 always crashes when transmitting 900mbps+ (wirelessly only) for more than 10 seconds
This router performs normally with light traffic until it transmits more data. You can stay connected to the network for a bit but even the router's internal web interface will not load. Then you hav...
  • plemans's avatar
    Jan 13, 2020
    have you tried to see if the issue happens if you're not running wan port aggregation? I've seen issues with arris running wan port aggregation on my RAX200.
