Gport16
Aug 22, 2020Aspirant
RAX200 And Airtime Fariness
So in an effort to not go crazy and get the best WIFI I had a few questions. With everyone home, 2 chrome books for zoom all day meetings, laptops, xbox , roku etc... What options might be best or ...
xjn
Aug 24, 2020Apprentice
Gport16 wrote:LOL ....Nobody???
Search Google for "Duckware article on AX routers" to learn about the features and then decide for yourself... it is not one size fits all so cannot really say.
Gport16
Aug 24, 2020Aspirant
Thanks will do
- avtellaAug 25, 2020Prodigy
Some clients have issues with Air Time Fairness, I would leave it disabled as I've seen odd latency issues at times. Last time I used it was on an R8500 but it caused my Chromecast to have stuttering issues during streaming. Maybe things improved since then but if I recall I had a similar issue on my RAX80 but didn't retest since a while.
- Gport16Aug 25, 2020Aspirant
Thanks
What options do you run? Beamforming? MU-MIMO?
- avtellaAug 26, 2020ProdigyLeave beamforming on.
As for MU-MIMO it only helps in certain conditions and that too it is mostly effectively on Qualcomm chipset based routers like the R7800 and RAX120.
On Broadcom chipset based routers like the RAX200 I’d leave it off. In last gen Broadcom routers like the R8500 and Asus AC88U it actually caused a performance drop often times. Maybe BCM improved it this gen but I haven’t seen any benefit on the RAX80 which is essentially an RAX200 minus the extra 5Ghz band and uses the same BCM chipset. Additionaly some BCM based MU capable WiFi clients like the Galaxy S6 or 7 would drop to half their capable bandwith when MU was enabled on routers.
