jvhaslup
May 19, 2022Star
RAX200 and HTTPS
Even after enabling the HTTPS setting in the Web management section, under the advanced category, I’m still getting the “this is not a private connection”, “invalid certificate” errors on my various w...
jvhaslup
May 19, 2022Star
Even after enabling the HTTPS setting in the Web management section, under the advanced category, I’m still getting the “this is not a private connection”, “invalid certificate” errors on my various web browsers.
1. Should I be concerned?
2. How do I resolve these issues?
Thanks!
Thanks!
- microchip8May 19, 2022MasterHTTPS most likely uses a self-signed certificate. Do you really need HTTPS? If you only access the Web UI locally, it's not really needed
Otherwise you need to force your browser to accept the certificate. Refer to browser settings
