chuckmorr1s
Feb 16, 2021Aspirant
RAX200 and PS5 - Moderate NAT
Hi all, I have my PS5 hooked up to my router. I've set the router to reserve an IP address for the console's mac address, which it obtains everytime. I've used port forwarding to open all the...
antinode
Feb 16, 2021Guru
> Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Firmware version? Conected to what? (Some other router, perhaps?)
> [...] port forwarding [...] uPnp [...] DMZ [...]
If one of them doesn't do the job, then I wouldn't expect much from
the others.
For the usual problems with port forwarding, see:
https://community.netgear.com/t5/x/x/m-p/1859106
Pay particular attention to item "1".
- chuckmorr1sFeb 17, 2021Aspirant
The firmware version (V1.0.3.106_1.0.58) which is the latest I believe.
I have a wireless fibre connection which my ISP gives me an IP for my routers MAC address. My router connects directly to the dish.
Thanks for the link, I'll run over them and maybe probe my ISP for a little help.
I factory reset the router last night and used everything default and still had a Moderate NAT in-game. The game itself requires UDP 3074. Whilst I was playing, I logged into the router and it showed on the uPnP port map table that port active and assigned to the consoles IP but it was still moderate in-game.
Thanks for your help.
- antinodeFeb 17, 2021Guru
> [...] my ISP gives me an IP [address] for my routers MAC address.
> [...]Everyone's ISP does that. The question is whether your router gets a
public (WAN/Internet) IP address or a private one (which implies another
NAT router between yours and the Internet).> [...] My router connects directly to the dish.
And if we knew everything which was behind your "the dish", then that
information might be more significant. "Necessary but not sufficient."> [...] maybe probe my ISP [...]
Good idea. I'd prepare for disappointment.
> [...] it showed on the uPnP port map table [...]
I'd expect explicit port forwarding or DMZ to do their jobs, too, but
that's not good enough when there's another NAT router in the path.- chuckmorr1sFeb 17, 2021Aspirant
antinode Apologies for the fluffy details. I'm hitting the limits of my networking knowledge.
Yes my ISP give me a public static IP and they use the least NAT possible on my connection.
