hkenr
May 07, 2020Initiate
RAX200 and readyshare PRINTER
I upgraded my router from a nighthawk R7000 which supported a USB printer. (READYSHARE). It appears th RAX200 only supports USB storage devices. Is that correct and I'm out of luck? Also, I canno...
- May 11, 2020
Hi hkenr,
The RAX200 currently does not support ReadyShare. In regarding to the WPS button, I would recommend contacting our support team using the link below as I've seen other threads of users reporting a similar experience.
The EX7000 should work with the RAX200 router and you should have no issues.
https://www.netgear.com/support/default.aspx
Christian
Christian_R
May 11, 2020NETGEAR Employee Retired
Hi hkenr,
Christian
- hkenrMay 12, 2020Initiate
Thank you for your reply.
But contacting NETGEAR SUPPORT directly is almost impossible. They provide NO email support at all, so you get a case number, call and hold, hold, hold....That's the reason I went the community route.for the issues. The EX7000 extender installed without a problem by the way, so thank you for that.
