hkenr
May 07, 2020Initiate
RAX200 and readyshare PRINTER
I upgraded my router from a nighthawk R7000 which supported a USB printer. (READYSHARE). It appears th RAX200 only supports USB storage devices. Is that correct and I'm out of luck? Also, I canno...
- May 11, 2020
Hi hkenr,
The RAX200 currently does not support ReadyShare. In regarding to the WPS button, I would recommend contacting our support team using the link below as I've seen other threads of users reporting a similar experience.
The EX7000 should work with the RAX200 router and you should have no issues.
https://www.netgear.com/support/default.aspx
Christian
Christian_R
May 11, 2020NETGEAR Employee Retired
Hi hkenr,
Christian
hkenr
May 12, 2020Initiate
Thank you for your reply.
But contacting NETGEAR SUPPORT directly is almost impossible. They provide NO email support at all, so you get a case number, call and hold, hold, hold....That's the reason I went the community route.for the issues. The EX7000 extender installed without a problem by the way, so thank you for that.
