pax7
Aug 07, 2023Aspirant
RAX200 as second router
my configuration is as follows: MODEM <-- WIRED ROUTER <-- RAX200 WIRED ROUTER: 192.168.0.1 Tried with/out reserved 192.168.0.2 RAX200 - connected to wired router via WAN port (also trie...
microchip8
Aug 07, 2023Master
Router after router is asking for troubles. What you have is called double NAT. There should be only one router in your network, not two or more, as they will fight over your network. Read the link below and put the second router in Access Point mode.
https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
pax7
Thanks for the reply - yes, a bit of trouble but not too much.
If I set the RAX200 in AP mode, I can't connect anything to it, even though I see the wireless network.
The main reason I want the RAX as a 2nd router, is to connect things on the guest network and don't allow them to see the rest of the network. I was trying a big brain config like that.
- michaelkenwardAug 08, 2023Guru - Experienced User
pax7 wrote:
If I set the RAX200 in AP mode, I can't connect anything to it, even though I see the wireless network.Then there is something wrong with the setup.
What do you mean by "can't connect anything to it"? What are you trying to connect and how?
You will not be able to get at the browser graphical user interface (GUI) on the RAX200 with the usual address. You have to track down the IP address that the router has allocated to it and throw a browser at that. (Hint, you can fix the IP address on the RAX200 either on the RAX200 itself or by reserving it on the main router.)
As you have discovered, your plan to use the RAX200 connected to the anonymous router won't work. Not a bad device or a firmware bug. Just a wonky configuration.
That's what AP mode is designed for. I'd fix that rather than trying to rewrite the rules of networking.
Then there is this:
I'd investigate how to achieve that before experimenting with a network setup. First is it even possible? Second are there other ways to achieve it?
