Same story here. I was about to go as far as the factory reset after finding the firmware update to V1.0.2.92_1.0.50 didn't work for me either. A factory reset will only reset with the most recent firmware, hence the issue likely remaining. Someone may want to try rolling back prior to 1.0.2.88 to see if NG broke the Matrix with that last major firmware update. They did improve the device list in that release...
RAX200 Firmware Version 1.0.2.88
New Features and Enhancements:
- Supports NETGEAR Armor
- Supports NETGEAR Circle parental control
- Improves the device type and model detection
- Includes dashboard enhancements to support CPU/Memory utilization indication
- Supports OFDMA enable/disable per radio
Bug Fixes:
