Fearphil
Jul 01, 2020Aspirant
RAX200 attached devices
My attached device list shows devices that are not even connected. i.e....There are known (i know the MACs) devices still showing on the list even through i dont use them anymore. My old router ...
Ragetti
Sep 20, 2020Tutor
I am still seeing this problem too, even after upgrading to the latest firmware. I also have issues where a wires device shows as wired.
Does anyone else have a fix for this yet?
- SSgt93Sep 25, 2020TutorI’m having this issue as well.
I’m going to say that my decision to try Netgear instead of ASUS this go around has been a bad one. Paying for security that is subpar, and (was) paying for Circle which flat out sucks has been an unpleasant experience. I actually feel like I’ve gone back in time with this router compared to all of the standard features included with my old ASUS GT-5300 ROG router. I’m considering ditching this and going to the AX-11000. I should have researched more before buying. I’m also losing more signal range and strength over the air than my old ASUS.- Christian_RNov 18, 2020NETGEAR Employee Retired
Hello Nighthawk AX Users,
If you're still experiencing issues with the attached devices list, please send me a private message with your email address and serial number.
Thanks,
Christian
- Armorgen99Dec 26, 2020Aspirant
Hi,
Some of my devices are showing as wired , but they are in fact wireless.
I'm also not sure this is updating correctly as I have noticed that the device count remains the same if I check from day to day and I know some devices are powered down.
Can you please confirm if this is a common issue?
Is there another way to get the IP address of a device other than the attached option? as I sometimes need to look up an IP address of a device using its make of mac address and I believe with the attached device option be not refreshing correctly then I’m seeing the old IP address instead of new one.Thanks
ColmAnd
Happy Christmas.
