DJScotty9000
Oct 27, 2022Tutor
RAX200 AX11000 Wi-Fi 6
I have a curious question. How many years do you get Netgear Firmware Updates for a Router. Like for example I bought it in 2021 last year.
- Oct 27, 2022
Several years? The R7000 was released in 2013. Almost a decade ago and still getting updates.
But thats not the case with all products as some of them get much less updates. A lot depends on who they sources the chipset/wireless chips from.
So you can usually get a few years and even more for other devices. Its not something we can say "you get XXXX amount of years"
Oct 27, 2022Guru - Experienced User
DJScotty9000
Oct 27, 2022Tutor
Thanks for the quick reply that’s certainly reassured me
- FURRYe38Oct 27, 2022Guru - Experienced User
You can also check into 3rd party FW as well. If they support various NG routers, they tend to keep the FW update flame burning as well.
