DJScotty9000
Oct 27, 2022Tutor
RAX200 AX11000 Wi-Fi 6
I have a curious question. How many years do you get Netgear Firmware Updates for a Router. Like for example I bought it in 2021 last year.
- Oct 27, 2022
Several years? The R7000 was released in 2013. Almost a decade ago and still getting updates.
But thats not the case with all products as some of them get much less updates. A lot depends on who they sources the chipset/wireless chips from.
So you can usually get a few years and even more for other devices. Its not something we can say "you get XXXX amount of years"
DJScotty9000
Oct 27, 2022Tutor
Thanks for the quick reply that’s certainly reassured me
Oct 27, 2022Guru - Experienced User
You can also check into 3rd party FW as well. If they support various NG routers, they tend to keep the FW update flame burning as well.
