cloudmaster2017
Aug 06, 2021Follower
RAX200 AX12 - Separate 2.4ghz, 5ghz-1 and 5ghz-2 / IoT / Google devices network inconsistency
Issue History: I've had issues with my IoT / google nest devices since day of getting the Netgear RAX200 device. My google devices disconnect frequently, I've tried it all, played with all the featur...
Aug 07, 2021Guru - Experienced User
No. the "load balancing" wouldn't work if smart connect was disabled.
If you're going to disable smart connect, I'd use all different ssid's so you can actually balance the setup yourself.
The AX speed/features would still work as normal with smart connect disabled.
