lowrisk
Nov 12, 2019Tutor
RAX200 (AX12) : GUI not responsive
I'm not sure what to do but I have a lot of issue with the GUI, I managed to turned of after 20 try the WiFi schedule, no I don't need it anymore, can't turn it off, the tick box is not working, I ca...
- Nov 13, 2019
lowrisk wrote:
I'm not sure what to do but I have a lot of issue with the GUI, I managed to turned of after 20 try the WiFi schedule, no I don't need it anymore, can't turn it off, the tick box is not working...
I'm afraid I can't follow what is going on here. Probably my fault.
What are you turning off? The video is hard to follow.
Is this an attempt to control the wifi?
I don't get this bit:
"I managed to turned of after 20 try the WiFi schedule, no I don't need it anymore, can't turn it off"
Turn off the wifi schedule?
lowrisk wrote:
I can't seems to disable the WPS neither ...
If you mean you want to turn off the WPS LED, you can't.
michaelkenward
Nov 13, 2019Guru - Experienced User
- lowriskNov 13, 2019Tutor
Sorry my post was very bad alright,
Basicly I coudnt disable the Radio schedule for 5Ghz (turn on/off at given time)
I coudnt disable the WPS option neither
Anyway the only solution I found was to factory reset, which I did.
Thank you and sorry for the post.
