Des73
Aug 18, 2021Aspirant
RAX200 (AX12) weaker & slower than R7000 - (I've lost 70Mbs and WiFi is plop)
Hi Guys, Ive just installed my new AX12 router in the same place as my old R7000. The only thing ive changed is the SSIDs to what I had before so all network devices can work again. (I will change...
Razor512
Aug 18, 2021Prodigy
If your area is not congested, on the WiFi settings, uncheck the 20/40MHz coexistance setting for the 2.4GHz band. Newer netgear routers have been more willing to drop to 20 MHz channel width when overlapping APs are detected. While it is useful if the overlapping APs are highly active. If they are not very active where you will end up with a ton of airtime sharing issues, then you will notice a near doubling of the performance on the 2.4GHz band.
For 5GHz, it should be significantly faster, The RAX200 with a 2 stream 802.11ax client, is able to deliver a real world throughput of 1.8Gbps to 1.9Gbps on a 2.4Gbps PHY rate. Furthermore compared to the R7000, it also has a significantly higher transmit power on both the 2.4GHz and 5GHz band. Beyond that, one area that Netger does well in, is improving receiver sensitivity and minimizing self-noise, thus maintaining higher speeds across a given range (less of a dropoff), thus even in those cases, performance still improves.
The one exception, is if you use DFS channels, If you do not have any devices that support 160MHz channel width on the 5GHz band, then change the WiFi mode from "Up to 4800 Mbps" to "Up to 2400 Mbps", this is because in the US the FCC unneessarily restricts any transmissions that enter the DFS range to a max of 250mW instead of the normal 1000mW. That will cause the router to use 80MHz channel width on the 5GHz band, which will allow it to avoid the use of DFS channels.
Depending on the AP, sometimes signal strengths can change, e.g., if you move from a model that has 2dBi antnnas, to 5dBi antennas, then clients a floor above or below the WiFi router will see a small drop in signal strength. Furthermore signal strength can be unreliable of some lower end WiFi adapters if very close to the router, since some lower end WiFi radios handle receiver overload rather poorly.
