toyboy9z
Mar 10, 2023Follower
RAX200 BRICK
i have a rax200.. boot loop after firmware update
I access via serial port..... and report the error here
can anyone guide me to solve this problem?
serial post
WARNING: can't open config file: /home/kate/Netgear/RAX200-V1.0.0.30_1.0.35_prebuild/targets/AX11000/fs.install/openssl.cnf
writing RSA key
Saving kernel bootup messages for dumpsysinfo...
/data/config.tgz: No such file or director
/sbin/hotplug2: No such file or directory
Reading board data...
hwtype=AX11000<,hwrev=
WSC UUID: 0x65ae77df942f80a43fa8fb126a867ef6
wps_uuid=0x65ae77df942f80a43fa8fb126a867ef6
read_board_data(750) region_num=9 2 (JP)
NTP synchronized date/time: Sun Jan 1 09:11:19 2023
MAC address of 1st STA connected: 34-08-BC-AE-B0-92
Internet Time date/time: Mon Nov 3 15:22:09 1969
set_led_settings(9192) state=0x1
abSwitchLedMapped 164 1
[gpio set] 25 = 1
abLedOnOff get abLedArrayTri[4].led=25 onoff=1 1/0 (GPIO_WIFI_2G_LED)
[gpio set] 8 = 1
abLedOnOff get abLedArrayTri[5].led=8 onoff=1 1/0 (GPIO_WIFI_5G_LED)
[gpio set] 9 = 1
abLedOnOff get abLedArrayTri[6].led=9 onoff=1 1/0 (GPIO_WIFI_5G_2_LED)
[gpio set] 54 = 1
abLedOnOff get abLedArrayTri[7].led=54 onoff=1 1/0 (GPIO_WIFI_SUMMARY_LED)
[gpio set] 29 = 1
abLedOnOff get abLedArrayTri[2].led=29 onoff=0 0/1 (GPIO_WAN_LED_2)
[gpio set] 28 = 1
abLedOnOff get abLedArrayTri[3].led=28 onoff=0 0/1 (GPIO_WAN_LED)
[gpio set] 20 = 1
abLedOnOff get abLedArrayTri[13].led=20 onoff=0 0/1 (GPIO_LAN5_WHITE_LED)
[gpio set] 22 = 1
abLedOnOff get abLedArrayTri[14].led=22 onoff=0 0/1 (GPIO_LAN5_AMBER_LED)
[gpio set] 46 = 1
abLedOnOff get abLedArrayTri[9].led=46 onoff=0 0/1 (GPIO_USB1_LED)
[gpio set] 47 = 1
abLedOnOff get abLedArrayTri[10].led=47 onoff=0 0/1 (GPIO_USB2_LED)
[gpio set] 25 = 1
[gpio set] 8 = 1
[gpio set] 9 = 1
[gpio set] 54 = 1
[gpio set] 25 = 1
[gpio set] 8 = 1
[gpio set] 9 = 1
[gpio set] 54 = 1
wl: wl driver adapter not found
Apply JP/901 as country code
### main:2163 Set Normal Power!
insmod: can't insert 'ctf': No such file or directory
insmod: can't insert 'ipv6': No such file or directory
Initialise conn table 2048 entries
Commit new ethernet config...
Doing nvram commit by pid 1 !
==== modules = hnd emf igs dpsta dhd wl
insmod hnd Done
insmod emf Done
insmod igs Done
insmod: can't insert '/lib/modules/4.1.51/extra/dpsta.ko': No such file or directory
insmod dpsta Done
insmod dhd Done
insmod wl Done
insmod: can't insert 'xhci-hcd': No such file or directory
insmod: can't insert 'ehci-hcd': No such file or directory
insmod: can't insert 'ohci-hcd': No such file or directory
cp: can't stat '/usr/sbin/app_patrol_all.conf': No such file or directory
cp: can't stat '/usr/sbin/app_patrol_clear.conf': No such file or directory
cp: can't stat '/usr/sbin/app_patrol.conf': No such file or directory
cp: can't stat '/usr/sbin/patrol_tq.conf': No such file or directory
cp: can't stat '/data/qos.conf': No such file or directory
cp: can't stat '/data/rule.trf': No such file or directory
cp: can't stat '/data/TmToNtgr_dev_mapping': No such file or directory
cp: can't stat '/data/TMDPI/archive/*': No such file or directory
[main(247)]: kaStartup() passed
[main(258)]: GetPolicy() passed (ret=663110)
nk_ioctl():54:open /dev/detector failed, ret=-1, err(6)=No such device or address
kaUpdateSig():566:trf_load error
[main(277)]: Failed to load the policy file!
[main(278)]: Trf format setting is FM - uptn.
killall: clean-cache.sh: no process killed
Stop iQoS...
Error: Cannot open file '/dev/idpfw' No such file or directory
result: NG
here rax restarts by itself!
thanks!
1 Reply
Try the TFTP recovery:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=hXhMgQS5k1o
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a Windows 7 PC and the TFTP worked.
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Try nmrpflash:
https://github.com/jclehner/nmrpflash
