bosyotech
Mar 12, 2022Aspirant
RAX200 Can't connect to 5ghz-1
Hi, I have an RAX200, Firmware Version V1.0.5.132_1.0.69. I have setup the access points separately with different SSIDs. I'm having trouble with the 5ghz-1 where no devices can either c...
bosyotech
Mar 13, 2022Aspirant
It’s using channel 44 up to 4800 mbps and 100% tx power. Doesn’t matter if I’ve enabled ax, beenforming or mu-mimo.
It gets worse, can’t even see ssid now.
Razor512
Mar 16, 2022Prodigy
Is this issue present for all 5GHz compatible client devices?
Which region was the router purchased and used in?
- bosyotechMar 16, 2022Aspirant
Yes any device. The same devices can connect to 5ghz-2 without problems.
Region is North America.
I have tried anything i can think of, downgrading to 1.0.4 which the router came with when purchased also upgrading from there to the latest while factory resetting every step.
Enabled/Disabled AX, beanforming, mu-mimo nothing helped. All channels from 36-64.
wifi analyzer shows that the SSID on 5hgz-1 consistently disappears/re-appears every few seconds.
Hair pulling all over my body now including places where the sun don't shine!
