anniyan
Jul 20, 2021Aspirant
RAX200 connect to Google Home
Hi Guys, I just bought this new device RAX200 Nighthawk Wifi-6. Overall it works amazing. But the main thing that made me purchase this thing is the functionality to connect/talk to Google Assistant...
- Jul 25, 2021
Hello,
I have fixed the issue. Its seriously redicilous and something Netgear have to fix!!!
After alots of searches over the internet and after i lost hope on this community for an answer.. I managed to find the answer myself! ... the answer is , the outdated Netgear app 'Netgear Genie App'. Which is absolutely dumb from Netgear to have it this way! How i fixed it, install this netgear Genie app, connect it to the wifi and enable the 'Remote Access' on this app and this fixed the issue, google assistant manages to talk to the router!!
Extremely stupid that netgear comes up an app for a latest technology router called Nighthawk, but not able to communicate to google assistant using nighthawk, but the outdated app netgear genie is needed to make the router communicate to google assistant.
Hope netgear employs the correct engineers & software developers to come up with softwares & apps for their product. Otherwise they are completely screwed i would say! They need to fire the current software developers and hire a good capable ones!
anniyan
Jul 22, 2021Aspirant
schumaku wrote:Just three steps required - key is the (App based) Remote Access, newly named Access Anywhere - start here: https://www.netgear.com/home/wifi/routers/google-assistant/
Hi There,
The 'Anywhere Access' option is enabled all the while ever since i setup the router and yet yesterday when i factory reset the router and re-setup i enabled that option again. Once done, i linked netgear to google assistant done, then i use google assistant issue the command 'talk to netgear' and then 'wifi status' or turn on guest network', yet Its the same response i got, your netgear router is offline.
:smileysad:
Please help..
anniyan
Jul 25, 2021Aspirant
Hello,
