JJJ-
Oct 23, 2020Initiate
RAX200 connectivity issues
I'm curious if anyone has had a similar experience with this router and more importantly with the customer support provided by NetGear. I purchased this router directly from Netgear a week ago. Set i...
ricozamora
Oct 28, 2020Tutor
My biggest issues has been constant disconnects for the past 3 months and have seen everything from them adding new firmware to them actually removing the latest firmware and downgrading it to the previous one. As of late with the current version of firmware I'm having the same as you with it dropping devices which didn't happen as much on the previous version of firmware. I can honestly say they don't seem to know what they are doing and sadly I should've known better the second I started having issues. As for giving up on the AX technology, I'll let you know once I get the very much less expensive Tplink AX router I just purchased in the mail! As for this VERY overpriced paper weight it's going into a box in my closet and MAYBE coming back out once Netgear get's their "stuff" together! Best of luck and if you still can,
Jan_F wrote:Had this router since yesterday and had quite a few problems already.
Im on the latest firmware - 1.0.3 -
Tried to name my devices via the PC (Wired Connection - over the Routers-Interface)
every 2-5.th device the interface became unresponsive (was not able to do anything about it, waiting did not help, 192.168.1.1 deliverd no more response / App did no work - only solution - restart the router)
After 2 hours of restarting and changing the devices names (22 devices connected) i was done (was almost 3 in the morning)
Now - after only about 11 hours of uptime - it started to drop devices - only 1 out of 7 Alexas were still connected, my Phone (Samsung s10+) was not able to connect to the Wifi anymore - (Problem with the Auth.) - My wired PC had NO INTERNET and was not able to log into the Router-Interface... i'm at a loss - such an expensive device and it simply isnt working.
Support was not able to help so far, they try to escalte it with LVL 2 - will wait for their response - depending on the response and the next few days - will either keep/send it back.
Had / still have a XR500 - never had problems like that - Don't know if AX is worth the hassle.
I would recommend returing this router and finding something that you can rely on.
Jan_F
Oct 28, 2020Tutor
Amazon is thankfully pretty generous with returns, the windows ends on January 31.th 2021 - today a few more bugs surfaced -
Had to disable the Armor feature - otherwise my TV wouldnt display 4k Youtube properly - endless buffering and stuttering - Buffer health ran to 0 all the time - took control with my Laptop / Phone - was able to gett the same resolution without stutters.
After disabling "Armor" the TV worked fine again (could be a coincident)
Now later today - same thing happened to my other LG 4k TV in the living room - Youtube 4k plays a while ... until i get the buffer symbol and it stops... 2 times now and those stops lasted for 30-60 seconds. (TV lost the WiFi as well -> while starting the Youtube App, had to retry to get connection back up and running)
I was really looking forward to this product - but i'm already tired of all those issues.
Got an E-Mail from lvl-2 Tech-support - asking questions about my setup ... wanted to answer them - but well, "
Page Unavailable
Sorry, but the requested page is unavailable due to a server issue.
Our engineers are working on it, please check back later."
Is what i'm getting while trying to send my answer... getting comically
This should not happen to the flagship product and shouldnt happen to their Site - but i guess thats normal - Was reflashing the latest Firmware and doing a factory reset and their Site gave me 20-40kb/s dl-speed on the latest firmware 71MB - had to wait over 25 mins for that file.
Really struggling with myself, I'm used to Netgear - all my previous network equipment came from them and up until now i was quite happy (except for a few things like the EX7700 repeater - which i tried to buy to give my XR500 a bit more life - sadly it lost connection and gave me "PW wrong" errors while repeating from my Xr500)
