JJJ-
Oct 23, 2020Initiate
RAX200 connectivity issues
I'm curious if anyone has had a similar experience with this router and more importantly with the customer support provided by NetGear. I purchased this router directly from Netgear a week ago. Set i...
pvhaver
Jun 28, 2021Aspirant
wow, well i have had a veru stressy 24 hrs.
I think my main issue is that the "smart connect" is far from smart and stops a lot of devices working. But then after switching back to non-smart mode i spend half a day rebooring and back to factory settings until eventually it seems to work again. I have been in IT over 30 years and like to think i have soem experience but this was very annoying and timely. a lot of my smart home plugs stopped working. my sonor speakers stopped working and at times it would just not allow me to connect to wifi at all. Most frsurating thing is that i have no clue what the frigging thing is doing most of the time. anyway it seems to work now for an hr or so and i am gettign on with work. I like the idea of the smart-connect as i would have one ssid and the rouiter would work it out. but it seems flawed. anyone else found this?
