ViRaL1
Feb 17, 2021Aspirant
RAX200 Constantly rebooting - less than an hour between reboots
I've had my RAX200 for less than a year. I've had it drop connection or had to reboot it here or there but it's gotten to the point now that it's rebooting on its on much more frequently (less than an hour between reboots). It's difficult to get things done work wise and it's made gaming difficult as well. Something this new shouldn't have this kind of problems.
- RajaDajaLuminary
Wow! something is go on! Overheating maybe? When did the reboot frequency increase? What about firmware? do you update manually or is it set to Auto? You could install a previous version of firmware if your're on the most current or visa versa . After evaluating & eliminating overheating & firmware, I would perform a factory reset.
- ViRaL1AspirantThings have been colder in the house, but not frigid. It should be well within normal operating temps. I am on the latest firmware and haven’t rolled back yet. I did a factory reset a few months back when I was having similar issues (but with less frequency) to no avail. I’ll see if a rollback yields any progress.
