pericopalotes
May 24, 2022Follower
[RAX200] Devices connected to the 2.4 GHz wifi are isolated
Firmware V1.0.6.138_1.0.76
Sometimes devices connected to the 2.4 GHz wifi are isolated on the LAN even though they are connected to the router, they are not "seen" from other devices. This is solved by resetting the router.
This problem has already been reported right here in 2020 but nobody replied, the thread was closed and Netgear, after 2 years, still hasn't fixed this problem.
It is impossible to contact Netgear technical support so the only thing that can be done is to open a thread in this forum which I have the impression is useless. đ«
What is clear to me is that I will not buy a Netgear router again.
1 Reply
I'll have to dig out my old RAX200 and try this this weekend and see if mine has the issue.
