Jimmy_W
Mar 19, 2021Guide
RAX200 DHCP drops connection for all clients
For some reason when DHCP renew happens on one device in my network it slows down all the other clients connected, even so much that it stops resolving sites or disconnect the clients from the servic...
Jimmy_W
Mar 19, 2021Guide
Thank you for answering antinode
I'm running the latest firmware: V1.0.3.106_1.0.58
The device is a Aircleaner.
I did not have this issue with my Ubiquiti Amplifi HD. Never had drops so i did not check the logs, the device might have requested it 3 times then also, the wierd thing it is requesting it every hour sometimes.
I have blocked the device, restarted the router. The device still showed up in connected device so i have now unplugged it.
I will see if i have the same issue the comming couple of days when the device is powered off.
If it is only that device i will reset it and not connect it to the WiFi. But i never had the issue on my Amplifi HD that is why I'm saying something is up with the router.
Jimmy_W
Mar 19, 2021Guide
The device is a electrolux Pure A9.
When i start it up again this happens. ( i removed the static IP)
[DHCP IP: (192.168.1.5)] to MAC address 78:0F:77:02:6D:E3, Friday, Mar 19,2021 12:57:33
[DHCP IP: (192.168.1.5)] to MAC address 78:0F:77:02:6D:E3, Friday, Mar 19,2021 12:56:06
[DHCP IP: (192.168.1.5)] to MAC address 78:0F:77:02:6D:E3, Friday, Mar 19,2021 12:54:55
[DHCP IP: (192.168.1.5)] to MAC address 78:0F:77:02:6D:E3, Friday, Mar 19,2021 12:53:57
[DHCP IP: (192.168.1.5)] to MAC address 78:0F:77:02:6D:E3, Friday, Mar 19,2021 12:53:15
- antinodeMar 19, 2021Guru
> [...] i removed the static IP [...]
Do you mean the (DHCP -- "D" for "Dynamic") Address Reservation?
(Which is not a "static" IP address?)
