trialcritic
May 06, 2021Guide
RAX200 download speed slow
I moved from an X10 router to a new RAX200. I have a 1150v modem. When I had the X10, I got a speed of 935 mbps. My ISP plan has a download speed of 1200 mbps. After the setup to RAX200,...
May 07, 2021Guru - Experienced User
How are you testing speeds?
What website and device?
Testing wired? Wireless?
Many site struggle with speeds >500mbps and will give unreliable results.
- trialcriticMay 07, 2021Guide
I tested with
- wired connection of my laptop to the router, with using Ookla speedtest and Xfinity speedtest
- using the Nighthawk app from my phone
I did the tests over 10 times at different times of the day.
Please note that the same sites had worked with my older X10 router
- plemansMay 07, 2021Guru - Experienced User
When you're plugged directly into the cm1150v, what speeds do you get currently?
I got 937 mbps when connected to the modem
