trialcritic
May 06, 2021Guide
RAX200 download speed slow
I moved from an X10 router to a new RAX200. I have a 1150v modem. When I had the X10, I got a speed of 935 mbps. My ISP plan has a download speed of 1200 mbps. After the setup to RAX200,...
trialcritic
May 07, 2021Guide
I tested with
- wired connection of my laptop to the router, with using Ookla speedtest and Xfinity speedtest
- using the Nighthawk app from my phone
I did the tests over 10 times at different times of the day.
Please note that the same sites had worked with my older X10 router
May 07, 2021Guru - Experienced User
When you're plugged directly into the cm1150v, what speeds do you get currently?
- trialcriticMay 07, 2021Guide
I got 937 mbps when connected to the modem
- plemansMay 08, 2021Guru - Experienced User
What firmware version is on the RAX?
Did you try a factory reset? After the reset, test the speeds without changing any of the default settings and see what you get.
- trialcriticMay 08, 2021Guide
I did a factory reset of the modem and tested the speed on it. I get only 720 mbps. I see large variations in the speed in the modem when I check multiple times. I guess the issue is with the modem and not the router.
