leardinet
Dec 04, 2020Aspirant
RAX200 DUAL WAN
I have just purchased a RAX 200 with the hope of a Wan aggregation of two connections, one FWA managed by the RAX 200 router with PPPoe protocol and the other with HUAWEI 4G + cat7 modem. I entered t...
Dec 04, 2020Guru - Experienced User
wan port aggregation isn't fail-over-dual wan control.
its designed for a single device connection to the router and through that to allow a consumer router to achieve speeds greater than 1 gig.
if you're wanting dual wan capability then you need to move to a business class setup.
- leardinetDec 04, 2020Aspirantsimply switch to the competition Asus GT-AX11000 ROG Rapture has dual Wan function. both in backup and balancing mode
- leardinetJan 18, 2021Aspirant
from what I understand it can not even manage the failover mode that if one line falls, the second is backed up.
So kindly explain to me to use the multigig wan what do I need? Upstream I have two PPPOE connections 100/10 and 30/5
