leardinet
Dec 04, 2020Aspirant
RAX200 DUAL WAN
I have just purchased a RAX 200 with the hope of a Wan aggregation of two connections, one FWA managed by the RAX 200 router with PPPoe protocol and the other with HUAWEI 4G + cat7 modem. I entered t...
Dec 04, 2020Guru - Experienced User
wan port aggregation isn't fail-over-dual wan control.
its designed for a single device connection to the router and through that to allow a consumer router to achieve speeds greater than 1 gig.
if you're wanting dual wan capability then you need to move to a business class setup.
leardinet
simply switch to the competition Asus GT-AX11000 ROG Rapture has dual Wan function. both in backup and balancing mode
