11oydyboy
Mar 17, 2023Aspirant
RAX200 Ethernet ports stop working
So I am having the same issue with my RAX200 which has worked fine for over 2 years.
Firmware Version V1.0.10.140_1.0.79. ISP is Virginmedia, RAX200 is connected to the VM Hub 4 in modem mode...
Mar 17, 2023Guru - Experienced User
I'd agree with Kitsap . Try putting the vm hub back in router mode (disable its wifi) and try the RAX in access point mode.
it wouldn't be the first time an ISP pushed out an update to their gateway and caused issues.
11oydyboy
Hi both
I will try AP mode since it wasn’t configured that way. What the hell it’s not working so happy to give it a go.
