11oydyboy
Mar 17, 2023Aspirant
RAX200 Ethernet ports stop working
So I am having the same issue with my RAX200 which has worked fine for over 2 years.
Firmware Version V1.0.10.140_1.0.79. ISP is Virginmedia, RAX200 is connected to the VM Hub 4 in modem mode...
11oydyboy
Hi both
I will try AP mode since it wasn’t configured that way. What the hell it’s not working so happy to give it a go.
Mar 17, 2023Guru - Experienced User
When you switched the modem to modem mode, did you reconfigure the RAX for router mode as well?
- 11oydyboyMar 17, 2023AspirantSure. I used the wizard and it worked for a few days.
- KitsapMar 17, 2023Master
11oydyboy wrote:
Sure. I used the wizard and it worked for a few days.Is the wizard some part of an application on a mobile device?
If yes, you need to connect to the router with a real computer, an Ethernet cable, and use a web browser to configure the settings.
- 11oydyboyMar 18, 2023AspirantThere is a setup wizard on the web UI. I did a fresh start and it’s working so far.
- FURRYe38Mar 18, 2023Guru - Experienced User
Does the router seem to be running hot or extra warm when this happens?
What happens if you place a USB laptop cooler fan under the router?
Downgrade FW back to last version of FW you had loaded?
11oydyboy wrote:
Sure. I used the wizard and it worked for a few days.- 11oydyboyMar 18, 2023AspirantRouter seems fine temp wise it’s on top of a side cabinet, the fan fires up on restarting but don’t normally hear it otherwise. Thing about this issue is that I didn’t consciously change anything before it started playing up.
