JohnDiV
Jun 24, 2020Star
RAX200 Firmware update 1.0.2.88 causing IPV6 issues
RAX200 Firmware update 1.0.2.88 causing IPV6 issues. After the 1.0.2.88 update in May the IPV6 will not autodetect, autoconfigure ect… WAN and/or LAN addresses causing IPV6 to fail IPV6 tests. No IPV...
Jun 24, 2020Guru - Experienced User
You're not the first to run into that issue
I know they (netgear) are aware of the issue and working on a fix. but that's all I know. No eta on the fix.
