bdonhbam
Mar 24, 2020Guide
Rax200 firmware update V1.0.2.8_1.0.45 causes the router to go offline every few hours
I just updated my Rax200 router with the firmware update V.1.0.2.8_1.0.45 this morning. It has lost connection to the internet 4 times so far today. The Netgear CM1100 connected by an Ethernet cabl...
bdonhbam
Mar 25, 2020Guide
I am considering rolling back to the prior Firmware version till this is fixed, too many times I get a complaint the Internet is down impacting their streaming, which is sudenly is more important in these days of stay at home orders...
Brice
psychopomp123
Mar 25, 2020Luminary
I'll give my RAX200 another chance. Done a hard factory reset and manually re-configured all settings from scratch. Hopefully it will behave itself now....
- psychopomp123Mar 26, 2020Luminary
Not had any disconnections since yesterday, current uptime is 15hrs. So maybe, just maybe, the factory reset has worked. I did the factory reset using the button on the back of the router instead of the software option.
- RajaDajaMar 26, 2020LuminaryI just setup my RAX200 yesterday, I follow the forums just for this purpose when new firmware comes out I haven’t updated yet. Are you still rock solid with your connections. The release notes indicate WPA-3 support, have you notice WPA-3 as an option since updating?
- bdonhbamMar 26, 2020Guide
My cable modem is rock solid and connected to the internet, It was the Rax200 that would stop connecting to the cable modem and stop accepting connections via wifi. I am waiting a bit before trying the above suggestion about a factory reset after the upgrade.
- RajaDajaMar 26, 2020LuminaryMy wife and I just started working from home prior to my router upgrade, her connection is WiFi and mine is Ethernet. Just don’t want any disconnections while working. I’ll update this evening. Which me luck!
- RajaDajaMar 27, 2020LuminaryJust a quick update; As I mentioned earlier, just got the RAX200 but I didn’t update firmware immediately. Well, I did last night, after updating the f/w I went ahead and perform a factory reset using the button on the back of the router. So far so go! The update seem to improve the routers functionality connection wise. My iPhone 11 Pro almost hit 800 Mbs down.
