bdonhbam
Mar 24, 2020Guide
Rax200 firmware update V1.0.2.8_1.0.45 causes the router to go offline every few hours
I just updated my Rax200 router with the firmware update V.1.0.2.8_1.0.45 this morning. It has lost connection to the internet 4 times so far today. The Netgear CM1100 connected by an Ethernet cabl...
NickM21
Apr 13, 2020Aspirant
The routers specs show up to 4.8Gbps WiFi speeds on 2 of the 5G channels. I don’t need to connect to more than 1 channel at a time. I’d be more than happy with the ability to get speeds up to 4.8Gbps. I currently only have a 1Gbps internet service coming into the house and can’t even take advantage of its full capabilities.
That’s the whole point of getting a new WiFi6 router was to get better speeds. Not sure why I spent $500 on a router that gives me the same speeds I got with my 5 year old Apple Extreme router.
psychopomp123
Apr 14, 2020Luminary
Even though the Iphone 11 pro is a capable of ax speeds, it might be connected at ac speeds. In iOS, download the ' Wi-fi Sweetspots' app and check the connection speed (link rate) to the RAX200. If its only 866 Mbps or less then the phone is NOT using the ax band.
