bdonhbam
Mar 25, 2020Guide
Rax200 firmware update V1.0.2.8_1.0.45 causes the router to go offline every few hours
I just updated my Rax200 router with the firmware update V.1.0.2.8_1.0.45 this morning. It has lost connection to the internet 4 times so far today. The Netgear CM1100 connected by an Ethernet cabl...
theronin_hunter
Apr 22, 2020Tutor
Following with great interest as I've started to get daily disconnects and suspected my Virgin Media modem was at fault
<a title="Broadband Ping" href="https://www.thinkbroadband.com/broadband/monitoring/quality/share/f1f8ee7463a897355df404b4879476383dcd44a1-22-04-2020"><img alt="My Broadband Ping - SH3-RAX200" src="https://www.thinkbroadband.com/broadband/monitoring/quality/share/f1f8ee7463a897355df404b4879476383dcd44a1-22-04-2020.png" /></
RajaDaja
Apr 22, 2020Luminary
thereonin_hunter
Couple things you can try Her
Here are a few things you can try
1. Revert back to the previous f/w
2. Download and install latest f/w over your existing f/w then reset to factory using the pin hole on back of router.
3. I heard that if you install the original f/w then update to most current. Then factor reset(pin hole method). The disconnect issues disappear. Good luck!
I
I
- theronin_hunterApr 23, 2020Tutor
Hi
So I tried this but that seemed to increase the frequency of disconnects. Over night as per the attached screenshot the router never fixed itself
2. Download and install latest f/w over your existing f/w then reset to factory using the pin hole on back of router.So I'm on this option at present but it too has just disconnected. I Removed then plugged in the WAN cable but that didn't fix it so had to reboot the router.
