bdonhbam
Mar 24, 2020Guide
Rax200 firmware update V1.0.2.8_1.0.45 causes the router to go offline every few hours
I just updated my Rax200 router with the firmware update V.1.0.2.8_1.0.45 this morning. It has lost connection to the internet 4 times so far today. The Netgear CM1100 connected by an Ethernet cabl...
RajaDaja
Apr 23, 2020Luminary
So, like a lot of us did.......we reverted back to the previous F/W. Have you tried? Go to Netgear support download and get it. For some such as myself no issues. Good luck
RajaDaja
Forgot to mention, recommended to factory reset after installing previous version of F/W
Also uncheck auto update in the update firmware section.
- lmanpunkMay 31, 2020Star
1.0.2.88 Firmware does not fix the issue. Both Wifi bands completely drop and dissappear for a few minutes. Can anyone recommend another brand that works well for them? My R7000 works better than the RAX200 but I have a lot of devices so I was looking for a better router. The RAX200 is not.
- dglsmcd_USMCJun 01, 2020Luminary
This is the first app I pull up whenever I have suspected issues with connectivity:
https://www.pingplotter.com/download
At first it may look rather cryptic but actually it tells you a lot and really narrows down where the problem is in terms of IP addresses-when an image of the PingPlotter is saved and provided to the ISP it provides both parties a clear picture of what is going on with your connection. Packet loss of course occurs whenever there are disconnects-this app pinpoints where the packet loss occurs first-that is where you need to focus your attention-do no be surprised if it is not your router. Give it a try and post your results here-a picture is worth a thousand words and there are a lot of people far more knowledgable than myself that can contribute a wealth of information. Hope this helps.
- lmanpunkJun 02, 2020Star
I ended up going to back to V1.0.1.12_1.0.41. It is not perfect but V1.0.2.8_1.0.45 was bad. My router went offline overnight until I powered cycled in the morning.
