RajaDaja
May 28, 2020Luminary
RAX200 Firmware Version 1.0.2.88 breaks ipv6
Hello,
RAX200 Firmware Version 1.0.2.88. Breaks ipv6 ! Is this suppose to be?
- RajaDajaLuminaryWhile fiddling around with ipv6 settings , ipv6 for WAN indicated ‘Not available’
Noticed the LAN ipv6 took, but not having ipv6 the way I normally see it configured. I downgraded back to previous firmware.- Christian_RNETGEAR Employee Retired
Hi RajaDaja,
Thanks for the feedback. Were you able to perform a factory reset after the firmware update?
Christian
- RajaDajaLuminaryYes, right after firmware update. Still no ipv6 configuration. IPv6 test fails . Online gaming shows ipv4. Use to show both . I guess I’m not missing much without ipv6. Oh well???
