RajaDaja
May 28, 2020Luminary
RAX200 Firmware Version 1.0.2.88 breaks ipv6
Hello, RAX200 Firmware Version 1.0.2.88. Breaks ipv6 ! Is this suppose to be?
crm813
Jun 18, 2020Initiate
I am having similar problems with the IPV6 disappearing after the latest firmware upgrade. The problem is that the updgrade includes many features that make my many IoT devices connect consistently to the router. My iPhoneXsMax connected to the router shows 2 IPV6 addresses, but my desktop and iPad do not. I also have an EAX80 hardwired to the router using CAT6 cabling as an AP for the upstairs - it also does not show an IPV6 address. The Xfinity . This is really frustrating that after spending $850 for these high end devices, all I get is a new problem. I installed the prior firmware on the routr, power cycled the cable modem several times (and between the set ups), reset the router and reconfigured things manually (not using a backup), and then upgraded, rest the router and updated things manually - I have spent way too many hours trying to get this high end equipment to function. PLEASE RELEASE A TESTED, FULLY FUNCTIONAL FIRMWARE UPDATE. PLEASE. I AM SO FRUSTRATED.
RajaDaja
Jun 18, 2020Luminary
I totally agree with you. Netgear firmware is riskier than ever. I want ipv6 functionality, it provides a more optimal gaming experience So I am currently on 1.0.2.8 firmware where I have ipv6 throughout my network of +30 devices. Still issues but tolerable......
- rinthosJul 03, 2020Luminary
Just wondering if any updates for this? Recently purchased an RAX200, and could not get it to pick up an IP from our business ISP.
Returned/Exchanged the router and no-go. Contacted support again and the answer is known issue, find another way to get internet access working or get a different router...not cool. So that's 2 being returned/sent back.
Anyone have any updates on a fix or firmware to use or other workaround?
Just as a sanity check, I also tried with firmware: https://kb.netgear.com/000062038/RAX200-Firmware-Version-1-0-2-92-Hot-Fix
But still cannot pick-up an IPv6 address. Put in our R8000P and a Linksys EA8300 and both are able to aquire IPv6 addresses, so it's not my ISP, definately this device/firmware.
