Dave-M
Nov 08, 2020Tutor
RAX200 Firmware Version V1.0.3.102_1.0.56 Issues
Ongoing horrible issues with this RAX200 router. Over a month now and multiple tickets to Netgear Gearhead support. There are a couple of issues, but this one is bad. When you remove ANY port forw...
Dave-M
Nov 08, 2020Tutor
I wish I could be as understanding as you are with a $600 router that needs to be factory reset every time it freezes up once or twice a week like yours does. I should have metioned that the firmware the router came with is 3 versions (maybe 4) lower then what was on the router in April 2020 when I got it. All 3 upgrades Netgear was "put the latest firmware on and see what happens." Since my issue has been ongoing since initial purchase I might feel a little better about saying "Netgear puts out subpar firmware regularly". Best of luck with your factory resets :-)
MaddmaxxAZ
Nov 09, 2020Initiate
So my router will out of the blue drop ALL the 2.4ghz CONNECTED devices for no reason what so ever. Paid for and contacted netgear gear heads, performed multiple firmware reflashed as well as factory resets to no avail. For $599 this thing should be bullet proof is anybody else having this 2.4 band issue?
- Dave-MNov 09, 2020Tutor
My old 2.4 Ghz devices drop on the regular with this particular router.
By the way, Gear Head support could not resolve my issue and Best Buy will not take this router back. So anyone interested in buying a slightly used Netgear RAX200?
- Dave-MNov 13, 2020Tutor
Turns out no one wants a poorly made $600 router that lets the entire internet in to your home network. Cannot say that I blame anyone.
Well.. I'm back on with Gearhead Support today with another technician and I'm getting super-duper escalated now for support. Interesting to see what happens as the tier 2 support tech actually agreed there is something wrong with this software/firmware/hardware. For those watching and reading... my RAX200 allows port forwarding rules to stay active even though they are removed from the admin GUI.
- lmanpunkNov 17, 2020Star
I have the $600 paperwieght as well. I had switched back to my r7000. I finally bought a TP-Link tri-band mesh 2 or 3 months ago and I have been much happier, Way more stable. I would never recommend any AX routers from Netgear.
