Dave-M
Nov 08, 2020Tutor
RAX200 Firmware Version V1.0.3.102_1.0.56 Issues
Ongoing horrible issues with this RAX200 router. Over a month now and multiple tickets to Netgear Gearhead support. There are a couple of issues, but this one is bad. When you remove ANY port forw...
roger1955
Nov 08, 2020Apprentice
Hi,
FWIW..... I remember going thru 2 RMA's with the 3rd router finally working as it should. It was a different manufacturer though. Just saying things like this happen. I just factory reset mine this morning, I get an occasional freezing of the router every 3-7days, so I decided to start doing a factory reset every so often, to see if the freezing whould stop....to early to tell. Overall, I have accepted the fact that sometimes Netgear puts out bad firmware which really screws up the router, but V1.0.3 working for me.
roger1955
Nov 25, 2020Apprentice
Still getting random zombie mode where the router just stops doing its routing thang. I only factory reset once. So the theory I was going to test is moot. (Doing a factory reset once a week is not what I want to do). Other than this, my RAX200 is awesome!
