mayo73's avatar
mayo73
Star
Feb 03, 2024
RAX200 Firmware
I noticed that the firmware for the RAX200 hasn't been updated in over a year. Is this router on the EOL list ? I checked and it doesn't seem to be . Expensive router with not much support it seems ....
  • plemans's avatar
    Feb 03, 2024
    Its not EOL but usually firmware updates fix bugs or security issues. Is there a bug you've got with it?
